TwinTurbo.NET: Nissan 300ZX forum - It's a little more than a Flash..
Subject It's a little more than a Flash..
Posted by Cjw3 on May 31, 2013 at 10:22 PM
  This message has been viewed 204 times.
In Reply To NA ECU can it be flashed for TT usage? posted by elcid on May 31, 2013 at 05:15 PM
Message The ECU Board needs to have components added/Changed to go from a NA to a TT control configuration. Generally keep the ECU Board 'Type' with the Original Design of the Chassis, to keep the wiring and control proper.. Then put a Prom in for the Type of Engine installed in the Car.. There are always exceptions to this rule..
So you might have a TT Prom, that will run a TT Engine in a NA Chassis, that has not been 'Converted' to a TT Control Configuration.
The Short answer.. find someone to supply you with what you need.. Sell or trade what you have..
Cj
